Fuel bypass regulator with 2 ports but only need 1...
ok so i ordered an Adjustable fuel pressure regulator with a return port because im swapping from EFI to carb and still using the EFI fuel pump
This AFPR has an Inlet a return port and 2 outlets
I bought it because i was going to order a carb that needed both, but i went with a cheap one from a friend until i have the money that only has 1 port for fuel
SO if i have 2 ports on the regulator and only need one can i just cap one off? or will that mess with something in the regulator??
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Re: Fuel bypass regulator with 2 ports but only need 1...
Cap it off. That's what I did and don't see any problems to it.
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I used all three supply ports. Two for the carb. (one to each float bowl) then I put a fuel pressure gauge on the third port. You can cap them though.
Car: 1990 Nissan 240SX
Engine: GMPP Gen0 350 small block
Transmission: WC T5
Axle/Gears: Nissan R200 3.133, Tomei 2-way
Well, let's think about it. The FPR pressurises fuel and adjusts the fuel pressure down to the level you set.
Pressurised fuel is then delivered to the two outlets. Any excess fuel will be returned to the tank.
What's the difference between one port sending fuel to the carb and the other port smacking the fuel against a cap? If your FPR is working correctly, nothing.
So I think you're okay. Just make sure the cap is pressure tight.
How about throwing a pressure gauge on there?
beachrodder
Aug 25, 2015 08:05 AM
bypass, carb, carburetor, difference, efi, fuel, gauge, issues, normal, port, ports, pressure, regular, regulator, regulators
