Intake manifolds
Old Oct 11, 2008 | 03:57 PM
kahless's Avatar
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
Intake manifolds
Ok guys i got another question. I have a 86 and up chevy 350 and im going to put a earlier style manifold on. what setup did you guys use to get your manifolds to fit your heads? I was thinking of removing the 4 center bolt holes all together just cut them out so it would fit!what did you guys do?
Old Oct 11, 2008 | 05:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Actually, it's '87-up.
Most people elongate the bolt holes in the intake manifold to get those bolts in.
Old Oct 12, 2008 | 04:22 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Re: Intake manifolds
thats what i just did about 4 days ago
then i made custom angled washers/spacers to compensate for teh difference in the angles. Also, i used a heavy amount of rtv filling the hole and then installing the bolt into the hole(seal up guaranteed)
i had to do it when i dropped a set of 083 heads on my 327
Old Oct 12, 2008 | 11:17 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What do you mean cut them out? Like physically cut the holes out of the manifold? After you did that how were you you planning on getting the manifold to seal?
Old Oct 12, 2008 | 11:36 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
i think hes talking about making a manilfold similar to vortech heads that do not use 4 center bolts.......
buuuut from what ive seen the outer bolts on a vortech are spaced farther away so spread the clamping force out(ie the bolts closer to center are move toward where center bolts uised to be)
Old Oct 12, 2008 | 01:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If the center 4 intake bolts come out at the same angle as the outter bolts, they they will be fine. If they are straight up, unlike the outter bolts, thats when you can run into problems. BUT, you can just elongate the center 4 bolt holes on the manifold to make them work.
You do need to use those bolts though, or it won't seal properly, and you will get oil and/or vacuum leaks.
Old Oct 13, 2008 | 05:42 AM
Hotrodder's Avatar
Car: 1934 Ford Roadster
Engine: 350 CSB
Professional Products make intake manifoils that fits both pre and after '86 heads.
They have special washers/spacers to add if it's going on a pre '86 heads motor.
Vortec heads require another intake manifoil.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
