hesitates at low rpms
Old Oct 16, 2008 | 10:28 AM
fbody5's Avatar
i have an 86 ta original a jet set up in the past couple of days it has developed a hesitation at low rpms the only code its throwing is the coolant temperature sensor i wondered if this sensor could be related to this problem thanks guys
Old Oct 16, 2008 | 11:56 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Could be. The computer uses that data to go to closed loop, and to determine operating parameters when in closed loop.
Old Oct 16, 2008 | 12:20 PM
fbody5's Avatar
Re: hesitates at low rpms
well i just got back from purchasing the sensor now just have to wait for it to cool down my fan is also wired to a switch {previous owner} i know this isn't the forum for that problem but maybe its all related
Old Oct 16, 2008 | 02:10 PM
fbody5's Avatar
new sensor is on and it did seem to help some it still wants to vibrate in drive at red lights and also does anyone know if i can adjust my idle speed its idling around 1200 in park wondered if i could bring that down some i looked for the screw to adjust it and the only screw i found had no way to turn it
jklein337
Sep 19, 2018 06:23 PM
777Shock777
Oct 29, 2015 04:30 PM
Jake_92RS
Aug 17, 2015 09:42 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
