what CARB for my application
Car: 88 iroc z28
Engine: 355
Transmission: Bowtie stg 3
Axle/Gears: 4:11
350 bored .30 over
Twisted wedge heads
LT4 hot cam
1.6 roller rockers
F.M pistons/rods
Performer 2101 intake
looking for a decent carb for my application, i was guessing a 650-700 dp would work.
suggestions?
Twisted wedge heads
LT4 hot cam
1.6 roller rockers
F.M pistons/rods
suggestions?
Car: 88 iroc z28
Engine: 355
Axle/Gears: 4:11
Re: what CARB for my application
cool.
no i havent, i had this given to me from a friend, would the performer allow it to rev quicker? better power band i assume.
Transmission: 4L80E/4L80E
The Performer is a slight upgrade from a stock intake.
The Performer RPM is a higher powerband dual plane intake that will better match your cam's powerband.
Probably more than that. The Twisted Wedge heads have pretty large ports. The Hot Cam will rev to 6000 RPMs easily. The Performer intake will hurt you starting at around 5000 RPMs, which would leave a lot on the table.
Car: 88 iroc z28
Engine: 355
Axle/Gears: 4:11
with my application, would it be smart for me to go to a larger cam? i have the front bumber off, all id need is to take the WP off, timgn chain cover ect... i just figure im that close why not. unless my setup now is fine.
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Id do the RPM intake. The Hot cam will go to 5800RPM and the Performer is good to just at 5000RPM. Considering peak power probably isnt 5800 but probably is still upwards of 5000. You are leaving some on the table there IMO.
Keep the cam, swap the intake
2012sergen11
Oct 13, 2015 07:38 PM
Damon
Sep 26, 2015 04:29 PM
