Wanting to switch from tbi to carb
Old Nov 12, 2008 | 09:04 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
is it possible to make a switch for under $450
It would be nice if i could a list of parts i need !?
Im on a tight budget but i need something that can move enough air for my 383.
So what do you guys think
Old Nov 12, 2008 | 10:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Used parts, probably. New parts, no.
Intake manifold, carb, distributor, gaskets, throttle valve geometry corrector bracket for the throttle arm, some means to lock up the torque converter.
Old Nov 12, 2008 | 10:25 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Re: Wanting to switch from tbi to carb
what size carb would you recommend? The 383 is basically has a little cam with i think stock 350 heads from what i can tell. I bought the car with the 383 already in it. And from what i can tell it still has the stock 305 throttle body on it. Not sure about the injectors. How much would the carb make on performance of the motor?
Tyler
Old Nov 12, 2008 | 11:00 PM
five7kid's Avatar
Really depends upon what else you've got there - heads, cam, exhaust, etc. A 305 throttle body is going to be very restrictive, a 454 TB would be better (requires intake modification to accomplish). On a mild 383, a 454 TB and properly tuned system with a carb intake and TBI adapter could come close to a carb in power, would do a lot better on fuel economy. The TBI forum has a bunch of information on TBI upgrades.
A 650-750 CFM carb is probably what you're looking for if you take off the TBI.
Old Nov 13, 2008 | 09:37 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
will the intake bolt right on?
I have a guy offering to sell me a holley projection intake and 454 tb w/ inj.
for like 200. Would this work?
How hard would it be to tune it?
Im looking at the ebl flash.
Old Nov 14, 2008 | 01:59 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
thanks a lot five7kid!
i decided to stay with FI.
Tyler
Old Jan 14, 2009 | 10:03 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
alright guys what do you think about this. i have a holley projection manifold. and a 454 tbi. would it be worth the effort to put the tb on with the 305 inj.
would i see a power increase? The reason i would like to stay with those injectors is because i dont have the ability to tune right now .
Thanks for all the help
Tyler
Old Jan 14, 2009 | 10:58 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
to the top
Old Jan 14, 2009 | 11:47 PM
five7kid's Avatar
The capability to tune would cost you less than converting to carb.
The ability - well, that can be learned.
Old Jan 15, 2009 | 09:34 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
what about if i used the 305 inj for now . and when i get the tuning equipment use the 454 inj? Would that be alright!
Old Jan 16, 2009 | 12:46 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
well if you mean putting the 305 injector into the 454 body that would defeat the purpose on the bigger body, you would be moving more air and starving the mixture of even more fuel
Old Jan 18, 2009 | 05:47 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
im buying new and all together including a cam is 560 without shipping for me.
Old Jan 26, 2009 | 07:49 PM
Car: 1991 Trans Am
Axle/Gears: Stock
hey if you still need injectors i have brand new ones 350 and 305 and used lmk Jon
BRoss99
Aug 10, 2025 05:08 PM
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
86IROC112
Aug 17, 2015 02:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
