Which do I choose new carb or engine?
Old Dec 14, 2008 | 09:50 AM
trav0302's Avatar
Car: 1986 trans am
Hey guys I have a 86 trans am with a computer controled quaderjet. I would love to get more power from it. But I would like to put a bigger carb on it and a high rise intake. Can this be done with this carb? Were could I find the parts. Or is it easier to pull the carb and computers and start with new ones? On onther note my timing is electroniclly controled to is this good or bad I seem to be desaling out at least three times a week this is my daily driver. And thanks for any help at all!!!
Old Dec 14, 2008 | 10:01 AM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
Re: Which do I choose new carb or engine?
That Q-jet will flow plenty for any 305 and probably enough for most modded 350's. The stock intake flows excellent for the way the engine is tuned,torque. An aftermarket intake may reap some benefits but it should be a 2 plane design. You can also adjust that carb with different jets,hangers,& metering rods as well as how quickly the secondaries open using an allen wrench and small flat blade screwdriver.
Old Dec 14, 2008 | 10:06 AM
trav0302's Avatar
Car: 1986 trans am
how do i stop the diesaling out? After I shut off the car it putts a few times then stuts off. On the same note when i hit the gas it hesitates for a sec. Then takes off how would i solve this?
Old Dec 14, 2008 | 10:24 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
well that is a function of timing. i think you have a vacuume advance on yours so its possible that your advance is not working properly. it only need to be off a hair for the timing to cause the problem.
Old Dec 14, 2008 | 11:34 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Dieseling is likely caused by a vacuum leak. Your timing won't cause a run on condition-the ignition is shut down when the key is turned to off.
Your stock distributor is computer controlled. You can't get rid of the ccc-qjet without also replacing the dist and installing another means for converter lock up. For info try:
https://www.thirdgen.org/forums/carb...ions-lg4.html?
Old Dec 14, 2008 | 05:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The computer system, carb and ignition, is the last thing to change when upgrading performance. When you do that, you now have a track-only car.
Excessively advanced ignition can cause dieseling by creating hot spots in the combustion chamber. Most likely, though, you've got things mis-adjusted. Get it all operating and adjusted to factory spec, including insuring you have no vacuum leaks, and your problem will go away.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
