Cc carb and Dist need Dist wire connections
Old Jan 22, 2009 | 01:45 AM
dKillaCamaro's Avatar
Car: 83 Camaro
Engine: 5.0
Axle/Gears: 3.73 open
mainly the little part that connects to fire wall cant find one plug thanx
Old Jan 22, 2009 | 11:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm not clear what you're asking here. Are you talking about the flat 4-wire connector, the distributor power, tach wire - what? Are you saying you need to replace something because it's damaged, or you can't find it on your car?
Old Jan 22, 2009 | 12:54 PM
Car: 83 Camaro
Engine: 5.0
Re: Cc carb and Dist need Dist wire connections
So there are two little single wires brown clips go to the Dist cap labeled bat and tach one **** from the wire harness beleive it gos to the tach side the other one bat gos to a little circle cylinder thing one bolt holds it to the fire wall so I don't know where to hook up the other end of the little circle thing thanx
Old Jan 23, 2009 | 01:51 AM
Car: 83 Camaro
Engine: 5.0
So where would the connector *** from for it
Old Jan 23, 2009 | 08:13 AM
five7kid's Avatar
I still can't figure out what you're asking.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
