electric pump and return line ?'s
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im going to be putting a external electric fuel pump on my car, and i want to use a return style system. Im using a fuel log on my carb and i would like to use one side as the inlet and the other side of the log as the return.
Will this work? i have little experience with return lines and want to make sure i wont have pressure issues. Im using a non return style regulator.
I would run a return style regulator, but with the layout that i have in mind, i dont have the room for the extra return fitting.
thanks
thanks
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: electric pump and return line ?'s
That's kind of the old-school way to do it, with a restriction at the end of the fuel log so that you're not just pumping all the fuel straight back to the tank. It doesn't work all that well though.
Car: 86 Trans Am
kinda what i figured, poo
Transmission: 4L80E/4L80E
If you used a relief valve instead of a regulator or needle valve, it should work.
Haven't seen it done, though.
Dialed_In
Aug 20, 2015 01:45 PM
