Ancient Holley metering block gasket removal
Old Jan 31, 2009 | 08:41 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Help I am rebuilding my Holley 4777 and the old gaskets are really stuck on the blocks , main body and bowls . I have scraped a Holley clean years ago , but it took forever . Is their an easier way ? .Soaking in some sort of solvent ?. Will a machine shop have some way of cleaning ?. This carburetor's gaskets are stuck badly . I feel that if I wear to scrape it clean , I would damage the carb with deep gouges and scrapes.
Old Jan 31, 2009 | 08:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Ancient Holley metering block gasket removal
Try soaking it in carb cleaner.
Old Jan 31, 2009 | 09:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are spray gasket remover products available as well.
Old Jan 31, 2009 | 09:34 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
So its the old elbow grease and spray , ain't nothing easy . Thanks
Old Jan 31, 2009 | 09:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try real dip type carb cleaner instead of spray.
Old Jan 31, 2009 | 10:07 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
let it soak overnight.
Old Jan 31, 2009 | 10:17 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
And find a plastic scrapper if you are worried about damaging the block.
Old Jan 31, 2009 | 10:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
plastic ice scraper for doing windshields, i like the small handheld ones and some carb cleaner or gasket remover that has been sprayed 3-4 times and let sit for an hour or so.
Old Feb 1, 2009 | 01:10 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Just bought a can of the real dip , I think it will work . In the metring block their are some plastic float stop or over flow reads . I do not know what they are . Will the come in the rebuild kit . I will end up breaking them trying to get them out . Is there any plastic on the throttle shafts .
Attached Thumbnails Ancient Holley metering block gasket removal-third-gen-photos-004.jpg
Old Feb 1, 2009 | 02:45 PM
lowflyr's Avatar
Car: 87IROC/88GTA/02Sierra/04GrandPrix
Engine: 406 / 305 / 4.8 / 3.8
Transmission: T56 / T5 / 4L60e / ??
Axle/Gears: 3.70 / 3.45 / 3.42 / ??
The plastic part you are talking about is the bowl vent. No need to break them, just remove the pin that holds them in. You'll have to get that out to replace them anyway, but no need to even replace them if they aren't brittle. They are there to stop sloshing fuel from going out the vent openings on the top of the carb.
Old Feb 4, 2009 | 05:49 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
The real dip works really well thanks for the help.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
