Cap return line?
Old Mar 2, 2009 | 06:54 PM
BlKnt18's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 L98 Carb. Alum. Heads
Axle/Gears: 3.08 Limited Slip
Cap return line?
On my 89 iroc that I bought awhile back, the previous owner swapped it out to a carbed 350 with an elec. fuel pump. He capped the return line and I was wondering if this was bad on the pump or not? Mainly I ask is because the old regulator is bad so I need to buy a new one. I thought about hooking it back up but idk if it goes to the tank and if it is any good. I could try it out but would rather not. Also, he says my psi sould be around 3 then he turns it up some in the summer and then more when racing. I thought I read on here that the psi means nothing, it just fills the bowls and should be between 4-7. Thanks.
Oh and what is the best fpr....I thought I heard mallory 4309
Old Mar 2, 2009 | 07:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Cap return line?
electric pump i assume? A working return line will keep the pump cooler and it will last longer
usually a carb need 4-7 psi.
Old Mar 2, 2009 | 07:14 PM
BlKnt18's Avatar
yup electric...its up there somewhere
Old Mar 2, 2009 | 08:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it is a factory-type in-tank electric pump, you need to use the return. And, the Mallory 4309 is the right type of part.
mike_c
Aug 27, 2015 04:32 PM
wayshegoes
Aug 17, 2015 12:00 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
