quick questions
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
quick questions
i just finished swapping my TPI to a carb setup and i have a few issues that im not sure where to start. first every time i start the car up i gotta give it some gas to keep it started, after about a minute or so it warms up and i can drive it normally. not sure whats wrong there. also ii noticed that my fuel pressure on the gauge only shows like 4 at any givven time, weather i rev it or keep it at idle? any ideas there. i tried to adjust the regulator and it dosnt move. and i have had the screw out completly LOL. the carb i have is a holley 750 with vac secondaries and the choke removed( prior to me getting it ) any help will be appreciated.
Car: 1984 camaro z28
Engine: L69 H.O
Re: quick questions
the reason you have to keep giving it gas is because that's what the choke is supposed to do it makes it idle around 2000 rpm until the engine is warmed up enough to run normally
Engine: L69 H.O
Re: quick questions
yes you can reinstall the choke but im not sure where you can buy it maybe one of the more experienced board members can answer this
Car: 1985 IROC Z28
Engine: L98 - 350/650 Holley DP
Axle/Gears: 3:83 Full Spooled
Re: quick questions
not an experienced board member, but I know Orilley's has one cause when i called up there to get an electric choke and then went to pick it up, they gave me the choke kit...
just to let you know. never did get the electic choke, have mine wired all the way open and that is exactly what i have to do on mine, some prefer electric, i prefer a manual choke cause come winter you need it on longer, and summer time you don't need your motor to idle that freakin high for that long.... that's why i like the manual, plus you can get that half choke to work at stop lights to really get your motor to sound weak (honda's love hearing weak motors... LOL)
Car: 1985 IROC Z28
Re: quick questions
since the 1985 camaro didn't have a 350 5.7L available, i always revert back to the 1976 ElCamino with the 5.7L 4BBL Carb. works every time for me. I have a Holley 750DP. Below is AutoZone's website and start search for you to go over. Hope it helps out a little bit...
http://www.autozone.com/N,14999999/P...rtsLanding.htm
Transmission: 4L80E/4L80E
If only the choke thermostat was removed, you can get that from Summit, Jegs, etc.
If all of the choke mechanism, butterfly, etc., was removed, it would be best to look on craigslist, racingjunk, eBay, etc.
Car: 1985 IROC Z28
If you ask for a choke for a '76 El Camino, you're going to get a quadrajet choke. You don't want that. You want a Holley choke.
Engine: 5.7/5.0
Re: quick questions
okay im new to carbs, and i know very little about it so far and i DO wanna learn. what i can do is i can take a pic of what i have and maybe someone can tell me what im missing. im not quite sure what im looking at when i look at my carb. i know the top butterfly ( the one on the chokehorn ) is not there if that is what you mean.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: quick questions
You're missing the butterfly, etc. The choke kit from Summit ($50) won't have everything you need. Maybe a call to carb's unlimited or one of the other specialty carb places is in order.
Engine: 5.7/5.0
Re: quick questions
i e-mailed carbs unlimited and im waiting on a response but im still not sure what parts FOR SURE that im missing. with the pics i took can anyone ID the parts i need for sure. im new at this and i dont wanna start ordering parts i dont need. i can take more pics if needed.
