rochester 4bbl
Car: 84 Z28
rochester 4bbl
i use to have a rochester carb on my car, there was a wire running to it i believe to advance the engine when the ac was turned on, i now have a 4175 holley on it, it there somewhere else to connect this wire to make it work ? Thanks.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: rochester 4bbl
Look up an AC kicker. They're pretty common. It's just an adjustable solenoid basically.
Try summit
Try summit
Car: 84 Z28
Car: 1982 Trans-Am
Re: rochester 4bbl
Universal to all holleys
I just found a handful on summit
search under brand "holley"
department "air & fuel delivery"
Part Type: "Carburetor Solenoids and Brackets"
There you'll see the brackets, and solenoids. You're looking around $100 when the smoke clears.
Car: 84 Z28
Re: rochester 4bbl
