Using electronic distributor with carb
Old Mar 24, 2009 | 08:01 PM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
I dont know if this has been asked before, because i couldnt find it. I was wondering if it is possible to use the TPI ecu/ignition on a carbed motor. For real control over the timing, not guessing based on vac and weights. This would also be helpful if the o2 sensor, map sensor, knock sensor, and other stuff like that was retained for datalogging and real time gauges. Basically just removing the injectors and Trottle body gear. Any way you could reprogram the 7730 ecu to run like this, missing a few things? thanks, Joe
Old Mar 24, 2009 | 09:19 PM
spanners's Avatar
Re: Using electronic distributor with carb
should work ok leave all the sensors in need tps attached to the carby and maybe turn off o2 sensor codes and leave the injector wires going nowhere should work fine
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Jlanz55
Sep 6, 2015 03:05 PM
rjcme
Sep 5, 2015 01:23 PM
