TBI air cleaner on an E4ME carb?
Old Mar 27, 2009 | 10:01 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Does an air cleaner from a TBI fit on the CCC Rochester? This one on a 4.3L V-6 looks to have a much bigger hose than stock air cleaner that came with carb'ed 305. http://i44.photobucket.com/albums/f2...320/stock3.jpg
Old Mar 27, 2009 | 11:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it's the 5-1/4" base, it will probably fit.
The snorkel looks bigger, but the hose looks like it necks down.
Old Mar 28, 2009 | 08:20 PM
Damon's Avatar
Re: TBI air cleaner on an E4ME carb?
I have a very similar air cleaner off my TBI big block. I tried fitting it against a carb one day- fit like a glove. However, I used a Holley carb for the testing. A Qjet uses the same diameter air cleaner flange, but I couldn't say for certain it would definitely fit. Watch the clearance on the underside of the air cleaner with the accelerator pump arm on a QJet- that's a common source of air cleaner interference with a QJet.
Old Mar 29, 2009 | 12:02 PM
scooter500's Avatar
Car: 87 Camaro Z-28
If it does fit on the stock carb, then welding a second metal air intake (or whatever the actual name is) from another TPI, onto one TPI air cleaner body, should result in an air cleaner that would be fairly close in performance and appearance to an HO air cleaner... just might work.
Old Mar 30, 2009 | 09:23 PM
Damon's Avatar
If you find an air cleaner housing from a big block TBI engine the snorkel that sticks out of it is a perfect mirror image of the one you posted the picture of. It looks almost exactly the same but points towards the passenger side. It would make for a very clean, very unique air cleaner setup the would probably flow every big as good, if not better than, an L69 HO setup.
Old Mar 31, 2009 | 06:27 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Thanks for the tip - it is time to go junking
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
