AN adapters
Old Apr 3, 2009 | 08:49 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
AN adapters
I'll keep this short.I'm plumbing some new AN fuel line from the stock mechanical fuel pump to the carb and wondered if the 3/8NPT to -6AN adapters will work for the connection at the ends.The adapters don't have anything to mate to the inverted flare on the pump and carb end .Will it seal up with just the threads or do i need some other type of fitting?Thanks.
Old Apr 3, 2009 | 09:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: AN adapters
they will not work, you need to buy the proper inverted flare fittings for the card and pump.
Old Apr 3, 2009 | 09:58 PM
vorteciroc's Avatar
Top Answer: 1
Re: AN adapters
If your fuel pump uses inverted flare fittings, you can use an inverted flare to AN adapter. Your fuel pump most likely uses 1/2-20 fittings but could also have 5/8-18 ports.
You need a adapter like this (1/2-20 x 6AN):
Old Apr 4, 2009 | 06:08 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Re: AN adapters
Thanks guys,guess it's back to Napa then....
InfernalVortex
Apr 20, 2021 11:31 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
romcjr
Sep 17, 2015 05:18 PM
