Rebuilt q-jet now car won't start?
Car: 87 Camaro
I had my girlfriends brother in law rebuild my quadrajet carb because my car was running really lean(i think) and would die when I put it in gear. I got it back and the choke butterflies are gone because the choke linkage was pretty much scrap, so I put it back on the car and now the car won't even start. The guy is a professional mechanic, he knows his stuff. It doesn't even seem to be firing. What are the possibilities here?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Rebuilt q-jet now car won't start?
Can you see fuel spraying? Have you tried starting fluid?
Car: 87 Camaro
Yeah the fuel is spraying...I can't tell if its flooded or not cause I cant smell and I don't know if its firing or not cause I was the only person there and I couldn't test it...But there was indeed fuel being sprayed.
Car: 1984 camaro z28
Engine: L69 H.O
if the car is flooding with gas then the plug will be really wet and if they are fouled out they will be covered in a thick black soot
Car: 87 Camaro
Ok well like i said I THINK it was running lean before I took it off. What are the symptoms or running lean vs running rich? These plugs can't have more than 20 miles on them. Of course they've been sitting for about 2 years...would they still spark?
Car: 87 Camaro
Nevermind I put some new Delco's on it and it started first crank
I haven't heard it run in years and it brought a smile to my face like noneother
I haven't heard it run in years and it brought a smile to my face like noneother Thread
