Holley with a cold air
Car: 86 Camaro IROC-Z
Transmission: 5-speed man
Within a month or 2 i will be buying a holley 750, and i want to do a cold air intake. I'm going to have it running up to the driver side front just beind the headlight. Was wondering is there a decent kit for that, or any way to home build it to there for about $100 rather than spending 200+ on the premade already?
Transmission: 4L80E/4L80E
There is probably a way to build it. What were you planning on starting with?
Most stock air cleaners won't clear the float adjustment nuts on Holley fuel bowls.
Re: Holley with a cold air
honestly, hadnt thought about it, i have a K&N filter on my edelbrock right now i was assuming that would work untill i got the other built. if not then was going to go check autozone. Any suggestions on that?
Brinkkl2000
Aug 4, 2018 08:29 AM
kyle5647
Aug 15, 2015 11:56 PM
db057
Aug 11, 2015 10:11 PM
