Best way to clean a carb
Car: 1991 firebird formula
Engine: 5.8
I got a used holley 4150 carb form eBay it has been sitting for a long time what would be the best way to clean off the old fuel, rust, dirt and all the crap in this old pos
Re: Best way to clean a carb
This is just my opinion and others will probably disagree. Stay away from the carb parts dip. Get some heavy duty detergent type kitchen degreaser (smart & final) and hot water. Use the degreaser full strength with various brushes and scrub the disassembled parts. Soak the small ones then brush with a stiff tooth brush. rinse with the hot (hot) water and blow it dry with compressed air. Then use aerosol can gumout to spray the small passages clean. Use "The Must For Rust"® for the rusty spots. Reassemble per instructions.
MantyZ28
23
Sep 29, 2015 11:33 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
