Ignition timing retards before advancing from an idle... any ideas?
Old Jun 3, 2009 | 06:19 PM
Mykk's Avatar
Hey Guys, have any of you ever had this happen before?
Scenario:
Chevy 350, 86-85 roller cam block 4 bolt mains.
CompXR276HR-10 cam & 1.6 rollers
Summit 850055 dist, MSD 6a, Accel Coil, taylor wires, NGK tr6 plugs
The Vacuum advance is on ported vacuum from the carb.
I set the timing to 32 degrees max @ 3100rpm and that landed the base timing to 14 degrees. When my engine is idling it's a steady 14 degrees, as soon as throttle is applied the timing gets momentarily retard to around 5 degrees before advancing like normal.
Check out this vid to watch what it's doing exactly:
http://www.youtube.com/user/04SilveradoMykk
(watch "ignition")
It will do this with or without the vacuum advance hooked up, and I think it's giving me my stumble/hesitation right off idle that I've been accusing the carb of doing.
Any ideas?
Old Jun 3, 2009 | 09:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"This video has been removed by the user."
Old Jun 3, 2009 | 09:26 PM
Mykk's Avatar
Re: Ignition timing retards before advancing from an idle... any ideas?
fixed
Old Jun 4, 2009 | 01:18 AM
five7kid's Avatar
Did you set it with the vacuum advance line disconnected?
Old Jun 6, 2009 | 08:50 AM
Mykk's Avatar
Yes, timing was set to 32 degrees max @ 3000-3100rpm without the vacuum advance hooked up. But the dist will pull timing like this with or without the advance hooked up.
Summit agreed there is a defect and they are sending me a new dist now.
I'm thinking of trying something when the new dist arrives. I will set it to a mechanical max of 32-34 degrees all in around 2800-2900rpm with a base around 12-14 but I will use a 15 (crank degree) vacuum advance @ 8" vac hooked into the manifold vacuum port on the carb.
This should give a base idle timing of 27-29 degrees and a cruise timing of 47-49 degrees. So we'll see what happens. Alot of the Ol' Timer hot rodders, engine builders & drag racers are using manifold vacuum for their advances. (with a lumpy cam & high compression) And it is suppose to yield a smoother idle, cooler engine temps @ idle, less idle fuel from the carb, more throttle response, less unburned fuel.
But not always, some engine combos react better to ported vacuum. So this will just be a test.
Old Jun 6, 2009 | 07:46 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Ported Vacuum is an emissions era crutch, nothing more. Engines respond best to Manifold vacuum as long as the rest of the timing is on. Some cams may want as much as 30-34* of idle timing.
Old Jun 11, 2009 | 11:03 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I didnt get to watch the whole video, but I did notice that you are using a timing gun with a digital dial back.
I had this exact same problem and it bugged the crap out of me for a long time.
You cannot use that style timing light with the MSD6A box. I talked to several MSD tech guys and they all told me the same thing. Cannot use a dial back/ digital timing light. I was using a snap on gun and had to borrow a friends gun that was probably 20 years old.
If you want verification of this call up MSD they will tell you.
tnrednneck
Aug 13, 2015 08:57 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
