Quad jet running rich
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Quad jet running rich
You're gonna have to do better then that bud. You need to help us help you, we can't read your mind.
- How do you know it's rich
- What OEM carb? That's like saying it's got an OEM engine. Is this computer controlled still? Are both the MCS and TPS set up and working?
Engine: 305 4bbl
I know its running rich because of the gas fumes that irritate my eyes while in the car.
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
hey maga, he is right, we need more information. Is the carb a computer controlled E4ME? Do you have any check engine lights on, possibly pointing towards a throttle position sensor? If you check on the side of the carb, you should find some numbers casted in. Write them down and send them our way!
Car: 1982 Trans-Am
305, 87, adjust, car, carb, carberated, carburetor, computer, controlled, jetting, quad, quadjet, rich, running, transmission
