fuel pump for carb and tpi
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I have 1990 camaro with tpi the fuel pump went out so I am going to replace next week. The question is (Is there a certain type that I can use temp. for the tpi that also will work for carb?) I will be changing to carb soon but I need to get it rolling with the tpi in use. Oh yea its elec. type in tank.
Thanks for the help and ideas.
Re: fuel pump for carb and tpi
you are goingto have to replace it with a tpi pump if you plan on using it for the tpi temp.. there is no way around it. as for going carb i believe that most are using the same pump with the return style regulator.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks that was what I thought but there is always something new out there, any suggestions on the best pump so I wont have to go back into tank anytime soon?
Car: 1990
Axle/Gears: stock
remember that your tpi is valuable and even more valuable if you take off every wire, cutting none, and doing the entire system - up to the firewall on the motor side and also up to the firewall on the passenger side.
they are great for 305's.
will he have to change out the lines?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Just don't get Autozone or Advance stuff, unless you're making the access panel so it's easy to change. I used a CarQuest pump - cheaper than stealership, and better than junk.
No fuel line changing whendo go to carb - just get fittings to attach to what you have, and definitely the return style regulator - nothing else will work - something like the Mallory 4309 regulator.
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
I got the mallory regulator on mine. Easy to setup and easy to tune. The hardest part was getting those metric bump fittings for the fuel lines.
Car: 1965 Chevelle SS
Engine: 355
Transmission: TH350
speaking of those fittings....What did you use? Where did you get them? I want to do like you did and adapt the existing fittings to either a barb or an 'AN' fitting
Car: 1992 Camaro RS
Transmission: WC T5
You'll need two fittings. 14mmx1.5 and 16mmx1.5 female to 6AN.
http://www.summitracing.com/parts/EAR-9894DBJERL/
http://www.summitracing.com/parts/EAR-9894DBHERL/
Engine: 355
Transmission: TH350
Car: 1992 Camaro RS
Transmission: WC T5
Yeah I looked for those for about a week before I found them. Glad I could save somebody else the trouble.
Heres the fittings for the TPI fuel rail FYI.
http://www.summitracing.com/parts/SUM-220009/
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
