ok so i have an 88 lo3 "stock " and i want to carb , i want to go edelbrock , now i want to make this transition easy as possible i dont want to buy a manaifold and a carb and then find out that i need other components and have to wait , so i want some suggestions on what i should buy , how many cfm's what intake manifold would best suit my application , manual or electric choke etc. my goal on my bird is to keep it mild kinda 300 ish hp , any suggestios would be appreciated
five7kid
close
Since your car is a 1988 model year, the only carburetor choice you have is a computer controlled q-jet system from an '88 Monte Carlo. No other carb is remotely emissions-legal.
so i cant throw on a performer series from edelbrock ?
Its physically possible, yes. It just won't pass emissions.
even if i get the intake manifold with the egr port ?
1qk4mula
close
Aside from your emissions problems.. you will need to replace your computer controlled distributor with a vacuum distributor. And if your cam is a roller u will have to swap the distributor gear.
five7kid
close
Quote:
Only a closed-loop computer controlled carburetor and distributor is legal for use on your car, and since your car is a 1988 model, only a system from an '88 or later certified vehicle is legal.Originally Posted by Birdstheword909
even if i get the intake manifold with the egr port ? Now that I think about it, I'm not even sure if a carbureted Monte Carlo was offered in California. Certainly no 3rd gen f-body was offered with carb in 1988, either in California or anywhere.
You're begging for a butt kicking at emissions time. If you're up for that, go for it.
so i pretty much cant do anything to my car,,,,,,
five7kid
close
Not with a carb, anyway.
dude..... that blows. not even if i had a 87 " wich was the last year gm used carbs" ?
If you had an '87, you could swap in a carb engine from another '87.
I don't know why you'd want to though, as you have 21 years of great engines to choose from.....
Quote:
Only if its a billit core cam. Stock hyd roller cams dont require the bronze gear. Neither did my comp hyd roller.Originally Posted by 1qk4mula
And if your cam is a roller u will have to swap the distributor gear. five7kid
close
And if your cam is a roller u will have to swap the distributor gear. Quote:
Thank you. I missed that misinformation being spread in this thread as well.Originally Posted by bluegrassz
Only if its a billit core cam. Stock hyd roller cams dont require the bronze gear. Neither did my comp hyd roller. Quote:
No problem. Originally Posted by five7kid
so , basically asied form all the cam mods and other stuff , there is no way a carbureted car can pass emissions test?
