Cold Air Intake On Carb
Transmission: 4L80E/4L80E
There's a tech article linked from the thirdgen.org homepage on building a dual snorkel intake.
The factory used cold air inlets on all third gens. The L69 had a dual snorkel arrangement, but those are getting harder to find.
www.ramairbox.com has a system made for our cars.
If you need to go through Envirotest, you need an air cleaner that has a heat riser system built into the snorkel. The home-built or factory air cleaners are the only ones that meet that requirement.
Car: 1983 Firebird
Engine: 327
Transmission: 5 speed, stock
Re: Cold Air Intake On Carb
I don't have to do the Envirotest, and I read the dual snorkel tech article but was wondering if there was a bolt on. I'll check out that website though, thanks.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
327, air, camaro, carb, carburator, carbureted, carburetor, carburetors, cold, double, dual, engines, firebird, intake, intakes
