Which Performer RPM intake do I use
Old Sep 15, 2009 | 09:27 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
I have a question that I need some help with. I have a 92 camaro z28 with the 350TPI in it. I am switching to carbureted and I am wondering which Performer RPM intake I need to use?
Can anyone help me?
Old Sep 15, 2009 | 09:44 AM
red30011's Avatar
Re: Which Performer RPM intake do I use
Not sure what your asking. I just bought the Edelbrock performer for mine, supposed to be for idle to 5500. Rpm performer is for 1500 to 6500 I think. I still don't know a whole lot but I figure if yours is mostly stock the regular performer intake will work fine. Plus you can pick them up somewhat cheap on ebay. Got mine for $80 with shipping.
Old Sep 15, 2009 | 01:15 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
non-vortec
Old Sep 15, 2009 | 02:09 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Non-vortec RPM Airgap with a dropbase air cleaner and a 2 1/2 in filter. Upgrade the cam/timing chain and valve springs while you are at it.
Dont forget the AFPR and some type of non CC dist.
Old Sep 15, 2009 | 02:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Certainly non-Vortec.
The bad news is Edelbrock doesn't make an RPM for the '87-up intake bolt pattern. So, you'll have to elongate the center two intake mount bolt holes on each side.
Or, consider a Professional Products Crosswind intake (knock-off of the Performer RPM Air Gap). It has the bolt holes already elongated and angled bushings to correct the bolt head contact face.
Old Sep 15, 2009 | 08:17 PM
Axle/Gears: stock
So as long as I elongate the center two intake mount bolt holes I can get a performer intake from 55-86 and it will work fine? someone said something about the distributor hole being off, is this true?
Old Sep 15, 2009 | 11:44 PM
five7kid's Avatar
No.
Old Sep 16, 2009 | 01:11 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
About the crosswind...: https://www.thirdgen.org/forums/afte...s-intakes.html
Get a weiand or edelbrock.
Old Sep 16, 2009 | 09:14 AM
Axle/Gears: stock
Hey everyone I thought I would let you know that I just bought a performer rpm intake off of ebay last night (amazing deal) and I am going to elongate the holes and put her on.
Does anyone know if I take out the computer and wiring harness if my gauges will still work? Also how do I set up the toggle switch for my trq convertor and when do I flip the switch? and why?
Old Sep 16, 2009 | 10:03 AM
five7kid's Avatar
The gauges go through the bulkhead connectors on the driver side of the engine compartment.
There is a tech article linked from the thirdgen.org homepage about setting up the lock-up switch. You switch it on when you're cruising. It zeros out torque converter slip for better fuel economy. But, it also reduces heat in the transmission - cruising without it will burn up your 3-4 clutch pack.
Old Sep 16, 2009 | 11:41 PM
Werewolf SS's Avatar
Car: 1989 Camaro RS
Engine: V6 - LS Swap Incoming
Transmission: 700R4 - T56 Mag F Incoming
Quick question lets say you do a carb swap but leave the ecm and harness in (just unconnected at engine related stuff) will you still need the TCC lock up switch rigged?
Old Sep 17, 2009 | 12:28 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Yes
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
beastin91rs
Oct 9, 2015 07:38 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
