What Fuel Pressure Regulator Should I use
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Can anyone help me out? I need a fairly inexpensive fuel pressure regulator for my tpi to carb swap. Which one should I use?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: What Fuel Pressure Regulator Should I use
All the brands at a regular source (ie NOT eBay) run about $80 - there's no cheap way around it (unless this eBay job is really a return style).
Axle/Gears: stock
Car: 1987 Trans Am
Engine: LQ9/L92
I also agree. Mallory 4309 is really the best option for this route. You have to use the return style if you are using a stock pump.
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
The procomp on ebay is not a diaphragm return-style regulator, which is what a factory pump requires. it is a "this can be a return style kinda sorta but it's really a dual-feed" regulator, and will NOT work for your application.
Holley makes a regulator that works like the mallory, search the 12-803BP.
9192camaro
16
Feb 3, 2019 12:21 AM
