Help choosing a carb
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
ok guys i've got an 88 camaro with a 3 spd auto 373 gears and a 3k stall. I'm going to be sticking in a stock 350 from an 89 formula. The only carb I have is a 750 demon. I don't know much about carbs but this just seems big especially since this is gonna be my daily driver for a little while. My question is will this work temporarily until I can afford a new one? and what is a good suggestion for a new carb on a budget? I've been looking at the edelbrocks they seem to be in the right price range but I'm not sure what size to go with. Will 600cfm be enough?
Also, what kinda mileage could I get with this? I'm sure it's going to be horrible but I'm just a little curious. Need anymore info just let me know.
Re: Help choosing a carb
You're correct a 750 Demon is too big for your little 350 in it's stock form.
Next Question is whic Demon? Speed? Mighty?
The 650 Mighty Demon Vac Secondaries would be a better choice, the Edelbrocks IMO aren't worth the price of the box they come in...but what do i know, i've only been doing carburetors for 40 years.
Price should not be the deciding factor in a carb purchase, good advice from a carb expert should be the decision maker. Unless you just like suffering and frustration.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm no long time carb guru, but I've had my Edelbrock 1405 for 3 years now, and have had no trouble at all. It was basically plug and play right out of the box, with very little adjustment, and I haven't touched it since the day I installed it - very easy, and well worth the $249 retail IMO. on the wallet
373 gears are going to kill mileage with any carb. I have 342's, and I'm getting 17mpg, so your 373's are going to be worse on the wallet.
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Well I think I'm going with a 600cfm edelbrock. The reason I choose this is because I keep reading about how simple they are and I'm complete newb to carbs. And price is definately a factor I just totaled my dd and have very little money to get this car together with.
and camaronewbie are you getting 17mpg's with a 3spd or 700r? I figure with a 3spd 373 posi mileage will be terribe.
If all you want to do is make it run then the Eddy will do the job, never on any engine I own but each to his own..."You can never exceed the speed of your wallet"
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
- I'm getting that with the 700R4.
