What jets/rods to use in stock LG4
Old Oct 31, 2009 | 07:57 PM
JoeMacGuy's Avatar
I swapped the stock Compu carb and distributor for a normal q-jet and distributor. The car runs great, but is a running rich. Any ideas on what jets and rods would be the best? I'm good with q-jets, just not with such a tame motor. Thanks Joe
Old Oct 31, 2009 | 08:01 PM
Damon's Avatar
Re: What jets/rods to use in stock LG4
What's it got in it now? Primary and secondary side.
Old Nov 2, 2009 | 11:12 AM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
You have a stock 305 with a stock CCC carb? Its running rich? Put a new O2 sensor in it, give the car a tune up, and tune the carb. The mixture is not so much set with the jets on these cars as it is set with the MCS. The reason your car is running rich is most likely a bad sensor sending faulty info to the computer.
Jeremys87
Jul 14, 2022 09:08 PM
RazorN8
Jan 7, 2022 11:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
