Purpose of a fuel cell?
Old Nov 16, 2009 | 05:33 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I am considering putting in one of the plastic 15 gallon fuel cells. What are the advantages of the fuel cell and how much of a pain would it be to install in stock spot?
Thanks, Chas
Old Nov 16, 2009 | 07:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Two-fold purpose: 1) Keeping the fuel line supplied under G-forces; and 2) safety.
Pain involved? You'd better have a good reason for doing it.
Old Nov 16, 2009 | 07:49 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: Purpose of a fuel cell?
ok you answered my question...im keeping my tank haha thanks
Old Nov 16, 2009 | 07:56 PM
always tinkerin's Avatar
Car: 85 Berlinetta
Engine: 408 SBC with a S-480 Turbo
Transmission: TH350/Hughes converter (Thank Pete)
Axle/Gears: 3:23 28.5" tire
If you wanna cure a starvation problem, just pull out your sending unit, chop off the 3/8" (or whatever size...it is too small for anything serious) metal tube, drill it out to 1/2" and weld in a 1/2" steel fuel pick-up tube, then run 1/2" hose to your carb. Works on my car for cheaper than a cell. 10 sec. E.T.'s easy. Don't forget to buy a big azz fuel pump, too. See the fuel can test on the Demon website.
Old Nov 16, 2009 | 08:19 PM
five7kid's Avatar
With a T5, you aren't likely to have a fuel starvation problem because of the stock 3/8" fuel line. . .
Old Nov 16, 2009 | 10:30 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
I haven't updated my sig yet but i have a built 700r4 with a 2000 stall.
Old Nov 16, 2009 | 11:07 PM
five7kid's Avatar
I have a 3/8" line on the '57. Moves 3800 pounds down the 1/4 mile to low 12's on E85 (requires about 40% more volume than gasoline).
You have to get to pretty serious power levels before the stock fuel tank and line become an issue.
Old Nov 17, 2009 | 05:54 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
im already running an inline holley fuel pump with the in tank sump (got the car that way.)
Old Nov 17, 2009 | 06:34 PM
87draggta's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: Th-400
Axle/Gears: 4.56 Richmond Gears
It sucks putting one in, unless you are drag racing then there is really no reason to do it, and even then you have to make a cover for it. I used a 12 gal I had laying around since I wanted to use a car and had a fuel injection pump and didn't want to change a bunch of stuff out. I used a 1 gal RCI, and ran a 1/2 aluminum fuel line to a mechanical fuel pump up front. The biggest hassle was making a cover for it.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Caspar
Jun 19, 2016 11:19 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
