Help, Pinging at Cruise at only 8 deg timing
Old Dec 11, 2009 | 05:59 PM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Hey guys,
I have a brand new 350 crate motor at 350 hp. I have a holley 600 electric choke carb. Timing is set at 8 degrees advanced and I still have that annoying pinging at cruise. I may have put mid grade fuel in last fill up, Im not sure to be honest. Motor only has 350 miles on it as Im still breaking it in. Any help or advice would be appreciated!
Old Dec 13, 2009 | 02:16 AM
GXR11's Avatar
Car: 91 C1500, 84 Camaro, 87 monteSS
Engine: 4.3L,Gen1 350. 391ci & 383 LS1
Transmission: t-5,man vavle body 700r4, no trans
Axle/Gears: 3:73, 3:42, 4:10
Re: Help, Pinging at Cruise at only 8 deg timing
my first guess would be a timing issue, did the crate motor come with the balancer and timing tab already installed, or did you have to do it, i.e. use parts from another motor. they are not all the same... i just cant grasp the idea of 8* and pinging...if that is the prob.
Old Dec 13, 2009 | 07:40 AM
Cflick's Avatar
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
I concur check the real timing. Is zero on the tab actually TDC at the piston ?
Old Dec 13, 2009 | 10:54 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Probably need more info on the setup. But what is total timing at cruising rpm? Maybe too much advance at that point, too much vacuum advance etc. Figure 36 total without the vac. adv. with another 10 degrees for that. If your cruising at 2500 rpm you might be over that some. And I'd sure run premium fuel in that engine.
Old Jan 3, 2010 | 07:17 PM
scaryjerry's Avatar
Transmission: t-5
sure its not a exhaust leak around the headers.?.... Sometimes it sounds like detnation.
Otherwise we need more infor on your engine.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Bull86
Aug 10, 2015 05:43 PM
