engine flooding
Car: 1987 Camaro
Engine: 355 4bbl
Transmission: tko 600
Axle/Gears: 12bolt 3.73
engine flooding
i need help u just built a 355 with 10.1 comp. i put a edelbrock 650 on it. right now its open headers. when i run it it runs for about 30 seconds then dies. and there is gas comeing out of the exaust. could it be flooding that bad?
Transmission: 4L80E/4L80E
Flooding is when gas overflows from the carb fuel bowl.
Most likely you're seeing the water produced by combustion. When the exhaust system isn't fully warmed up, the water vapor will condense before it gets out of the exhaust pipe and drip. Open headers will make that worse.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: engine flooding
make sure the fuel pressure is not more than 5psi.
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: engine flooding
Sounds like a fuel pressure issue...do you have a regulator on there? Is is a fuel injection pump?
