fuel pump question
Old Feb 13, 2010 | 09:15 AM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
fuel pump question
ok im switching from tbi to carb and i was wondering if i have to take the fuel pump out of the tank or can i just disconnect power to it. i already have the carb fuel pump and i know that i will have to drop the diff to get to the gas tank and then if i do have to pull the tbi fuel pump will i have to do anything special to make the carb fuel pump work with the stock lines? thank Ty.
Old Feb 13, 2010 | 09:21 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: fuel pump question
are you dead set on using the pump on the block? is the tbi pump bad? you could just install a regulater and not drop the tank. if you are going to drop the tank just install a pick up screen in place of the old pump.
Old Feb 13, 2010 | 09:53 AM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
after you saying that im not set on useing the carb fuel pump, i just thought that if i ran a car i would need the pump for the block, but no the tbi fuel pump is good, so all i will need to run the tbi fuel pump is get a fuel pressure regulator?
Old Feb 13, 2010 | 10:07 AM
one92rs's Avatar
Car: SOLD!!!!!
yes sir a return style regulater. go to the home page and click on tech articles. it gives the part numbers of some good ones. make sure it is a return style.
Old Feb 13, 2010 | 10:16 AM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
sweet well that just saved me a lot of time from pulling the diff and the tank, thanks A LOT!
Old Feb 19, 2010 | 08:07 PM
meadmarc's Avatar
Car: 89 Formula Firebird
Engine: 350 Vortec
Axle/Gears: 3.73 posi
I had the same question, ditto the thanks!
Old Mar 1, 2010 | 07:48 AM
shanebang76's Avatar
What if the in tank pump was replaced with a pick up screen? Would you still need a return style regulator?
Old Mar 1, 2010 | 09:04 AM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Then you would need an external pump. I'm using stock fuel pump and the Mallory 4309 with my Holley 80670.
Old Mar 1, 2010 | 05:51 PM
meadmarc's Avatar
Engine: 350 Vortec
Old Mar 1, 2010 | 05:55 PM
91stroker's Avatar
Car: 1991 Z28
Engine: GMPP 383 w/AFR's 750 vac.
Transmission: 4L60
Axle/Gears: 9 bolt 3.70
Hey, just curious where did you mount the mallory and do you have a regulator before the mallory as well as after? I have a stock tpi high pressure pump and when cranked down to 6 psi it just doesn't flow enough for my 383.. I was planning on buying a 255lph pump but it doesn't flow much at low psi for my holley.
Old Mar 1, 2010 | 05:56 PM
meadmarc's Avatar
Engine: 350 Vortec
Ditto above, I believe due to the design of the sending unit. Not sure if you could just block off the return if you are still using the in-tank pump, but I've found a new external pump is less expensive than the regulator.
Old Mar 1, 2010 | 06:03 PM
Jordo91rs's Avatar
Car: 91 camaro rs
Transmission: t-5
Axle/Gears: 3.23 gears
You could have kept the stock pump and just used an adjustable fuel pressure regulator. but since you already have the pump you can just get a pick-up and fuel lines from a carbed third gen tank at the junk yard and that should work just fine.
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not if you used a pump with an internal bypass, but there are still a lot of good reasons to use a return regulator.
Old Mar 1, 2010 | 06:04 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
i bought a holley blue pump. i am still using the 4309 mallory but the holley pump comes with its own regulator.
Old Mar 1, 2010 | 08:11 PM
91stroker's Avatar
Car: 1991 Z28
Transmission: 4L60
Yeah, that's what I'm running right now, problem is I'm not getting enough flow from my stock tpi pump. It's a new pump, but doesn't flow enough. I am thinking of a 255lph pump, but because they high flow at high psi, i'm not sure it'll deliver enough when regulated to 6psi for my holley? Has anyone run a cammed 383 with a 255lph pump?
Old Mar 1, 2010 | 08:35 PM
mos68x's Avatar
The Mallory 4309 is the pressure regulator. I have mine mounted on the driver's side strut well, right above the fuel lines. You shouldn't be having any flow issues with the regulator, it is really open on the inside. The only restrictions that I can think of right now might be your fuel line diameter, other than that maybe fuel filters that haven't been replaced.
Old Mar 1, 2010 | 08:37 PM
mos68x's Avatar
I tried that for a while, but I was having problems with mine so I spent the money on the regulator and cleaned up the install.
Old Mar 1, 2010 | 08:40 PM
91stroker's Avatar
Car: 1991 Z28
Transmission: 4L60
So are you using the stock tbi pump? I had a 91 RS Vert with a ZZ383 and stock pump and it never ran dry, I just can't fathom replacing a stock pump where a stock pump already is..?
Old Mar 2, 2010 | 08:12 AM
mos68x's Avatar
Yeah I saw no sense in dropping the tank if I didn't have to. Besides, why replace a stock pump if it still work fine and I just replaced the fuel filter?
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
