Running SUPER sluggish!!! HELP PLEASE!!!
Old Feb 13, 2010 | 09:00 PM
ssmtyper's Avatar
ok so i picked up an 86 iroc that had been sitting for 3 years... Initially I had to tow it home. Got the radiator and fan back in, new battery, freash gas and some "heet" a few cranks later and a shot of carb cleaner, it fired right up... it ran ok but was miss firing pretty bad... So I change the plugs and wires, cap and rotor, fuel filter, engine oil, tranny fluid, fuel filter and air filter. Wha La, it ran really decient had a little power(still didnt seem like enough) and was scooting around town ok.
Well over the past few times I have driven it, it seems to be getting more and more "slugish" (smells like its running pretty rich) it still drives ok at a slow speed or even if you just increase speed slowly. When I press the gass to the floor it makes no difference in speed, rpms, nothing but dumpin more gass apperantly...
It has what I assume is the original lg4 with quadrajet. the car is a 5spd
any help is greatly appriciated!!!
Old Feb 14, 2010 | 05:57 AM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Re: Running SUPER sluggish!!! HELP PLEASE!!!
did you rebuild the carb? Thats a long time to sit up.. probably a vaccum leak at the very least.
Old Feb 14, 2010 | 10:00 AM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Did you set the timing?
Check the fuel filter again.
I fought vacuum leaks after I got my T/A running. It was sitting for several years as well.
Might try some Sea Foam down the carb.
Old Feb 14, 2010 | 05:39 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
My suggestion is to find a book on q-jets and study it before you even touch the carb.
Old Feb 14, 2010 | 09:08 PM
ssmtyper's Avatar
Thanks for the fedback everyone.
I am definatly not carb knowlegable ( i usaually fix up newer cars) I will track down all my vacumes and make sure they are good and going to the correct place. And I was already considering running some sea foam so i'll do that too.
Does anyone else think clogged cat when they read about this trouble???
Old Feb 15, 2010 | 07:17 AM
stroker_SS's Avatar
Engine: 355
Well, here is a tool to test for any restrictions in the exhaust.
From what I've read 2-3psi is normal for a stock exhaust.
http://qualitytoolsforless.com/Produ...ProductID=2690
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
BADNBLK
Nov 16, 2016 09:12 AM
86IROC112
Aug 17, 2015 02:00 PM
Sherpajames
Aug 7, 2015 06:56 PM
