Quadrajet 850 leaking gas around carb
Old Feb 21, 2010 | 01:17 PM
smoothjazz's Avatar
Hi Everyone,
I recently got a used Quadrajet carb from a guy.When I put it on
my engine,gas is leaking badly all round it.Is this from a stuck float or
something?
Old Feb 21, 2010 | 02:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Quadrajet 850 leaking gas around carb
It could be. You put it on an already-carbureted car?
Old Feb 26, 2010 | 09:46 PM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
is it leaking from the bottom around? did you put a gasket under it, and if so, what kind of shape is the gasket in? could just be that. does the car have problems starting or does it just leak gas
Old Feb 27, 2010 | 06:19 AM
smoothjazz's Avatar
Its leaking from everywhere.Top,and bottom of carb,
Old Feb 27, 2010 | 11:17 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What fuel pump are you using? Fuel pressure? Have you checked the float level?
Old Feb 27, 2010 | 11:23 AM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
sounds like the usual quadrajet problem, gaskets have been ruined from sitting to long. the rebuild kits are cheap and the instructions are decent to follow for even a novice.
Old Feb 27, 2010 | 11:43 AM
smoothjazz's Avatar
I got it from a friend of mine.I spoke to him on the phone.He stated it sounds like the float.I sent it back to him,he is gonna look into it.It sounds like the float has some issues.
Old Mar 2, 2010 | 07:48 PM
csmith3's Avatar
Car: 70T/A, 87Formula, 02Hawk, 06 GTO
Engine: 400, 350, LS1, LS2
Transmission: M21, 700r4, T56, 4L65-E
Axle/Gears: 3:55, 2:77, 3:45, 3:46
You still haven't said if the car was originally carbed or not. This matters because of the fuel pressure.
Infested
May 22, 2018 11:56 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
wayshegoes
Aug 17, 2015 12:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
