EEC Canister Question
Old Feb 23, 2010 | 06:16 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I realize this is a little out of place here, but I bet this has come up in more than a few TPI-to-Carb swaps.
In my quest to migrate from the stock ECU to the EZ-EFI setup, I've run across an issue which I need help with. I have an 89 TPI Formula; my charcoal canister is not compatible with the new EZ setup, I'd keep it if I could however it is controlled by the stock ECU so I think it has to go.
I'm guessing the best option is to plug the line from the tank and install a vented gas cap (which i have). So...what do i plug the line with? I know whatever rubber has to be fuel-safe but I'm unaware if fuel-safe caps are available. Moreover, is this still a safe method to use?
Also, if you have a better option please chime in.
Thank You.
Eric
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Thaney9
Aug 29, 2015 03:16 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
