Edelbrock 600 help
Old Mar 27, 2010 | 10:54 AM
Hubbardj6's Avatar
Car: 1984 Z28
Engine: 355
Axle/Gears: stock
Edelbrock 600 help
Just got carb- got it running decent. starts and runs normally when cold. but if i shut the car off and try to start it a few mins later (example: getting gas) it takes alot longer than normal to fire, and when it does fire, i get about 3-4 mins of extremely rough running. if i dont keep giving it a constant supply of fuel it will die. but then after a couple minutes POOF its gone. like it never happend, and the car starts running totally normal. please help! thanks in advance.
Old Mar 28, 2010 | 02:00 AM
mario 91-87's Avatar
Car: 91 and 87 camaro
Engine: 91 360ci and 87 350ci
Transmission: lt1 t56 ,wc t5
Axle/Gears: 3.23 2.42
Re: Edelbrock 600 help
i have the same carb but 800 i had a similar issue some time ago and a was the floaters the carb was overflowing in gas. hope this help
Old Apr 19, 2010 | 06:18 AM
Hubbardj6's Avatar
Car: 1984 Z28
Engine: 355
Axle/Gears: stock
i just adjusted the floats, it still does it. what did you do to fix yours? thanks
Old Apr 19, 2010 | 06:42 AM
Awesome-X's Avatar
Car: 87 Camaro
I have the same issue but I haven't figured it out yet. I think its too much pressure in the tank because when I take the gas line to the carb off it spews gas for about 45 seconds. And thats with the car off...and only after its been up to operating temp.
Old Apr 19, 2010 | 09:21 PM
sumnerslayer's Avatar
Car: 1982 Camaro Coupe, 2004 Grand Prix
Engine: 6.0 iron block LS, series III 3.8
Transmission: T56, 4T65-E
Axle/Gears: 3.42s<--hate em...need some 4.30s
Do you have any kind of spacer under the carb?? Sounds like your getting to much heat transfer from intake to the carb, get a heat insulating gasket or a phelonic spacer. Check these out
http://www.jegs.com/p/Moroso/Moroso-...43742/10002/-1
http://www.jegs.com/p/Edelbrock/Edel...43637/10002/-1
I had the same exact problem, actually when i parked my car and shut it off i could hear gas bubbling inside the carb, WAY TO HOT!! Bought a Edelbrock Wood Spacer and poof!! all better!! Starts great now
Old Apr 19, 2010 | 09:23 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I have this same exact problem with my Edelbrock 600. I may try this. Of course I've also got sticking throttle with it as well.
Old Apr 19, 2010 | 09:52 PM
Hubbardj6's Avatar
Car: 1984 Z28
Engine: 355
Axle/Gears: stock
I may have found out something intresting today. When i open my gas cap i get a pretty significant "woosh" or sucking sound, gonna take a wild guess and say that its from pressure in the tank. so i put the cap back on but only threaded it a couple turns. car seemed to start without trouble for the couple times that i tried it. but it could just be coincidence, seeing as how my car WOULD fire up and run normal..but it was rare. So ill post soon with more results.
also, this is all going on at operating temp. thanks for everybodys input!
Old Apr 20, 2010 | 01:55 AM
Awesome-X's Avatar
Car: 87 Camaro
Yeah I tried that gas cap thing a few weeks back and it worked for me, too. Like I said a pressure release gas cap should do the trick.
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
toronto formula
Sep 10, 2015 07:31 AM
