my 305 is running rough
Transmission: 4L80E/4L80E
75% of the time, carburetor problems are caused by ignition.
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Re: my 305 is running rough
ditto!
I would check timing, then check gaps in the plus if there new, if they have alot of miles on them or look bad replace them, check wire connections and wire conditions, make sure their not shorting out at any place, also check/clean cap and rotor replace if necessary
