q jet 4 barrel won't open?
Old 04-25-2010, 12:27 PM
russlavoie's Avatar
i have an 87 camaro with a 4 barrel q jet electric choke. I have no idea why but the two big barrel won't open at all. Any ideas?
Old 04-25-2010, 04:43 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: q jet 4 barrel won't open?
Well, not sure how you know they "won't open". Because the engine has to be under load to have them open. They will not open if the car is sitting in the garage and you just push the throttle wide open.
Old 04-25-2010, 05:11 PM
russlavoie's Avatar
yea it was just sitting in my garage i diddnt know it had to be under load
Old 04-25-2010, 05:44 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
they won't open if the choke isn't fully open. I had mine setup where they would open when you winged the throttle, you have to loosen the air valve tension screw for it to do it, but i had richer rods so it wouldn't bog.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
Fronzizzle
09-08-2015 12:10 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: q jet 4 barrel won't open?
