hesitation issues
Old May 3, 2010 | 01:48 PM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
hesitation issues
Ok,
car starts up and idles fine now, I took the carb apart and cleaned the whole thing, new gaskets all the way around.
The car will idle at 1000 rpms, I can even put it in gear, the rpms will drop down to like 600 and stay running, my issue is if i give it gas, it will bog terribly, then take off like a bat outta hell. same thing happens in park, if you rev.. it falls on its face.. then will rev up fine..
the weird thing is, when the car first starts before the choke opens all the way up, it revs fine, no hesitation at all.. but the rpms are also above 1000 too.. i dunno.. anyone got any ideas?
Old May 3, 2010 | 04:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
One thing I have ideas about is what kind of carb it might be, but I wouldn't take that to the bank. . .
Old May 3, 2010 | 04:15 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: hesitation issues
why such a high idle. the transfer slots have to be fully opened. but like five7kid said. what kind of carb.
Old May 3, 2010 | 04:55 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Hi Hecter, Throttle tip-in enrichment is provideed by the accelerator pump. Did you by chance forget to install the check ball? Also check float level. Double check for any vacuum leaks. High idle when cold is normal (fast idle cam). Be sure you have the idle mixture set right. Good luck
Old May 6, 2010 | 11:38 PM
hectre13's Avatar
Engine: HO 5.0
oh sorry, its a holley aluminum street avenger, 670cfm.. electric choke, vacuum secondaries.
Old May 7, 2010 | 03:45 PM
hectre13's Avatar
Engine: HO 5.0
I just uploaded a video of the hesitation issue, lemme know what you think.
http://www.youtube.com/watch?v=yFe5Iq0CfHE
Old May 7, 2010 | 08:31 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Usual question... what is your idle timing? Running vacuum advance?
Old May 8, 2010 | 11:10 PM
hectre13's Avatar
Engine: HO 5.0
I hooked up my timing light today, and i cant even see my timing mark.. umm.. is this a bad thing? if i retard my timing too much, it will start to stumble. I am running a vacuum advance dizzy.
Old May 9, 2010 | 07:28 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Not necessarily bad, but it is your foundation to tune upon. You may need to put a timing tape on to see exactly where it is. Unhook vacuum can and see if it shows up. Are you using a dial back timing light?
Old May 9, 2010 | 08:39 PM
hectre13's Avatar
Engine: HO 5.0
nope, its a cheapo timing light. what is timing tape?
Old May 10, 2010 | 10:15 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Literally a piece of tape you wrap around the harmonic damper. Line up the 0* mark on the balancer and tape and stick it down. Clean the balancer real good first. You need to know the diameter of the balancer on your motor, either from a service manual or measure it yourself. Better to measure and know for sure.
http://www.summitracing.com/parts/MSD-8985/
This will let you map out your timing as that needs to be right before any carb tuning commences.
Old May 10, 2010 | 11:35 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
You should have no problem seeing the timing mark. What I did was find the mark on the balancer and ues either white out or some white touch up paint to high-lite the mark. Then set the timing as you would normal. Now if you rebuilt the carb did you turn the screw to the acc pump at all? If so you might have to re-set it to holley factory settings. You can see how to set it here:
http://www.youtube.com/watch?v=w3F3ssOb8lg
Holley has a youtube channel and you can find a lot on info there.
Old May 10, 2010 | 09:30 PM
hectre13's Avatar
Engine: HO 5.0
oh gotcha, ill see what I can do with this.
There is no problem with it being too hard to see, the problem is my timing is advanced so far that I my light cant hit it.
I didnt touch the accelerator pump screw at all actually.
Old May 11, 2010 | 08:26 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Do some searching, you can probably even make a timing tape from masking tape or something to get you going....
http://www.crankshaftcoalition.com/w..._a_timing_tape
Old May 11, 2010 | 02:03 PM
hectre13's Avatar
Engine: HO 5.0
update:
ok, so I havent got my timing figured out yet, but I did fix the hesitation issue. I bought a set of the accelerator pump cams.
after trying different sizes, I found one that helped, and after adjusting the acc pump spring, it runs soo much better.
still seems a little hesitant, Im thinking deff my timing.
Vojtush31
Oct 11, 2015 01:07 PM
webeeZ28
Sep 14, 2015 12:00 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
