Fuel filter problem..'83 Z28
Old May 4, 2010 | 05:45 PM
HotRodLarry's Avatar
Car: '83 Z28
I'm having problems gettin my Z28 to start. It sits for weeks at a time and usually fires right up. I changed the fuel filter last October and ever since then, it takes a long time for the car to start up. Today I took everything apart and noticed the check valve on the filter was almost out of the filter.I set the check valve back to where it is supposed to be and the car started right up and ran fine for a few minutes.Can I take that check valve out or should I look for a filter from a different brand?
Old May 5, 2010 | 07:44 PM
1983Zsled's Avatar
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
Re: Fuel filter problem..'83 Z28
Are you talking about the filter inside the carb? I think you fixed the problem, but I do not recall seeing that before. Maybe you fixed it or maybe you could just buy a new one.
I just use a generic filter from Napa, seems to be fine.
Old May 8, 2010 | 09:46 PM
Car: '83 Z28
Pretty sure I fixed the problem. I just wanted to give the car a couple days in case that was it. That check valve might be something that should be looked at real quick next time anyone else decides to change the filter on those cars.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
