1406 on '83 5.0
Car: 1994 Trans Am
1406 on '83 5.0
I just bought a truck with this carb on it. Is it any good? Does it have reliability issues. It looks pretty new, the guy I bought it from doesn't know much about cars in general and I don't know much about carbs. I've read it's a 600cfm street carb. Im not looking for performance at all, just give me some education on it. Electric choke??
Transmission: 4L80E/4L80E
They usually come with an electric choke.
If it's the carb you've got, and it's set up properly (electric choke powered, vacuum/mechanical advance distributor installed and adjusted properly, etc.), then it'll be fine.
Reliability issues are usually caused by neglect or abuse.
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: 1406 on '83 5.0
The Edelbrock carbs are numbered at the front drivers mounting bolt tab. my 1406 is an electric choke and still on the shelf since I woke up and realized just how good the q-jet really is.
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
Re: 1406 on '83 5.0
I've got a 84 TA with a 305. It had a Edelbrock 1406 when I bought it. The car ran, but was sluggish and a bit of a gas pig. I just put on an Edelbrock 1403 500 cfm and what a difference. No longer sluggish, better idle and I waiting to see on fuel mileage. The stock 1406 definately over carburetes the 305.
