thread sealer
Old May 31, 2010 | 10:00 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
thread sealer
What kind of thread sealer(that won't eventually leach) can I use from my fuel line where it screws into my carb? It is all new and shouldn't leak,none the less,it does. Thanks
Old May 31, 2010 | 01:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What type of carb? Exactly where is it leaking?
Old May 31, 2010 | 06:08 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Re: thread sealer
It is on a Holley 4160 and I have resolved the issue by smoothing out the flare fitting. Leak has abated. Thanks for the inquiry.
Old May 31, 2010 | 09:16 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: thread sealer
Just to keep this going, what are some good thread sealers that are compatible with gasoline? Teflon tape is the only one I really know of that won't eventually degrade because of it.
Just looking for something better for my mallory AFPR, has a slow slow leak around the plugs that is driving me crazy
Old May 31, 2010 | 09:42 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: thread sealer
the white teflon will still eventually degrade its better to use the yellow teflon for gas piping in houses.(IE stoves, heaters, water heaters, etc.)
the white stuff is UL rated for water only, the yellow is UL listed for Petroleum products.
Old May 31, 2010 | 10:01 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: thread sealer
ACE sells thread sealant compound in a tube, safe for gasoline, works like a charm.
Old Jun 1, 2010 | 01:45 PM
five7kid's Avatar
The reason I asked is thread sealer is inappropriate for most carb fittings.
Glad you got it fixed.
Pac J
May 17, 2020 10:44 AM
Elephantismo
Feb 13, 2019 12:51 AM
355tpipickup
Sep 28, 2015 05:50 PM
Linson
Sep 21, 2015 01:08 PM
