need help with my timing
Old May 31, 2010 | 10:19 PM
Jazz T/A's Avatar
Car: 82 Trans Am, 68 El Co, 84 K5
Engine: Carb 350, Carb 327, 6.2 Diesel
Transmission: Borg-Warner T10, TH-350, 700R4
Axle/Gears: 3.23, stock 10 bolt, 3.73
ok so i just rebuilt my motor i re did every thing but upgraded to a high flow oil pump and a bigger cam. the car never ran right before the rebuild. but now its fine when the computer connection is disconnected from the distributor. but when its plugged in the car wont stay on it idles 900-1000 for a sec then drops till it dies all in 2 seconds from the car being started. and if i rev the car too hard it backfires.
NE ideas?
PS my cam is a Crower stage 3 cam. the specs are AD=288°/298° at 112°. with a lift of .444/.464. and my timing is set to 8°.
im driving it to work local with the distributor disconnected and it runs fine but it feels like it lost its grunt if u know what im sayin.
i need this fixed asap if it can damage the motor
Old May 31, 2010 | 11:00 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: need help with my timing
either your distributor module is bad or your ccc carb needs a rebuild with new electronics
Old May 31, 2010 | 11:08 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
If your car is computer equipped, then what you are most likely going to need is a custom prom... if that's the case what's happening is that the ECM is trying to compensate for your bigger cam... if this isn't the case, then you need to do some research into how much more base timing your car may need...
Old May 31, 2010 | 11:29 PM
Jazz T/A's Avatar
first off i already rebuilt the carb i just didn't replace electronics. and the distributor is untouched so those are an option.
next my car has a computer controled carb so the prom might be it. but if that's the case im just goin to get a non computer distributor and carb and throw that in it.
if i did that would that fix it?
and thx for the fast responses i appreciate it a lot
Old Jun 1, 2010 | 12:27 AM
If you dont have to pass emissions and dont mind ditching the computer stuff then go ahead just remember to address the transmission if its an automatic.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
