pressure regulator
Car: 91 RS Convertible
Engine: Soon to be swapped
Transmission: Memphis performance 700r4
Axle/Gears: Soon to be changed
pressure regulator
Could someone tell me if this would be a suitable bypass style fuel pressure regulator to use when utilizing the stock tbi intank fuel pump?http://cgi.ebay.com/ebaymotors/Holle...Q5fAccessories
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: pressure regulator
That looks fine. The instructions show an option with the fuel line running to the carb first, then out to the regulator - DO NOT install this way - make sure the fuel line runs to the regulator first, then out to the carb. Says it's preset for 7psi - may need to adjust up/down for your carb - think I have mine set at 5psi right now. Grab an inline pressure guage at put it after the regulator but close to the carb so you'll know how best to adjust.
