Possible to fit 3/8" return line?
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I'm going to be replacing my fuel lines and installing an electric fuel pump and bypass regulator in near future. I know these things like having a big return line. Is it possible to order 2 prebent feed lines and use one for a return using OE brackets?
Transmission: 4L80E/4L80E
The OE clamps are sized for stacked 3/8" & 5/16" tubes.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Possible to fit 3/8" return line?
Yes, that would be possible, but the line on the sender itself is 5/16" as well. You would have to modify the sender.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you were reading my posts about having problems with the mallory 4309 and the stock return lines, don't worry - I found my issue and it had nothing to do with the 5/16 return line size - I'm running fine now and have no problems getting the 4309 to adjust down as low as 3psi from my TBI pump.
Car: 1985 Z28
Hey Camaronewbie what pump are you running? If I'm going to drop the tank I wanna do it right and drop in a Walbro 255 so I won't run out of fuel with future upgrades, but I wanna make sure it won't over power the 5/16" return.
ambainb
Apr 25, 2016 09:21 PM
