swapping or changing over to a carb
Old Aug 12, 2010 | 09:05 PM
RMR94's Avatar
Car: 92 camaro
Engine: 305 bonestock sbc
Transmission: 700/r4
hello i have a tbi on my 305 and i was wondering is it hard to switch to a carberautor? and also was wondering how much it would cost and what would i have to do? also was wondering if it adds any more horsepower and messes with the gas mileage? and one more thing does it make a sound difference?
Old Aug 12, 2010 | 09:23 PM
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
Re: swapping or changing over to a carb
You'd have to get a new intake manifold and a bunch of other stuff. It could cost a lot for everything unless you can find cheap parts. Your gas mileage will drop because carbs aren't as efficient as TBI.
Old Aug 12, 2010 | 09:32 PM
RMR94's Avatar
Car: 92 camaro
is there any difference in horsepower between a carb and a tbi?
Old Aug 12, 2010 | 10:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A carb swap on its own won't necessarily give you any more power than TBI, and if done wrong could certainly give you less. It can make it easier and less costly to make more power if done in conjunction with a bunch of other necessary changes, though.
Old Aug 12, 2010 | 10:16 PM
RMR94's Avatar
Car: 92 camaro
ooh alright i appreciate the help
Old Aug 13, 2010 | 01:25 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
I prefer the adjustability of a holley double pumper ( i have a 650 DP with an adjustable primary AND secondary metering block and a wide band hooked up) I have a 3500rpm stall converter and a 4:10 rear in my S10, (weighs ~2800lbs) it needed the dp the vac secondary carb I had on it never drove the way i wanted it to
though I love the concept of a Q-jet, I'll probably drop one on when i build a 302 for my trans am
Old Aug 13, 2010 | 04:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
1) It's not legal, but depending on your state/county you might get away with it (obviously alot of us do)
2) It won't (on it's own) add any hp
3) You'll need a carb, intake, vac advanced dist, fuel pressure reg, and if you are automatic tranny, a TV cable corrector and a method to lock the torque converter - all that is about $600 - $800 depending on the carb and intake chosen
4) You WILL lose gas mileage! Properly tuned, your TBI should get almost 30 hiway, my carbed 350 only gets 17. The TBI F-bodies were the most fuel efficient V8's in the generation.
Old Aug 14, 2010 | 12:37 PM
Car: '84 Trans Am
Engine: 350 Carb
You can significantly boost the hp on your TBI and make it sound awesome if you do the right things to it. And it will save you the mpg's. First thing, is good quality headers and a true dual exhaust. You will notice the power difference and sound right off the bat with that. And that will cost about the same as swapping to a carb.
Old Aug 15, 2010 | 12:51 AM
RMR94's Avatar
Car: 92 camaro
how much would this cost? with the headers and exhaust thanks
Old Aug 15, 2010 | 12:04 PM
Car: 1992 RS
Engine: Carbed 350
Your best bang for the buck on 'seat of the pants' feel will be rear gears - start hunting the classifieds/craigslist etc. for a rear end with posi and better gears - in my 1990 I swapped from 2.73 to 3.08 and could feel it easily - 3.23's, 3.42's, or 3.73's will be a vast improvement. 3.42s are a good street gear - feels alot better off the line and still maintain some decent hiway mileage.
Exhaust is going to depend on brands etc. Headers and Y-pipe about $500, another $150 for muffler, your stock I pipe flows plenty right now. Have no idea on cat prices or if you need a new one. Duals are cool and all, but no real need with a 305 - not sure there's much of a need even with a 350 unless it's pretty large hp numbers.
Old Aug 15, 2010 | 02:00 PM
Car: '84 Trans Am
Engine: 350 Carb
The gear swap doesn't add hp, but I do agree it is definately something you can feel and is worth the upgrade. Don't really need a dual exhaust, but headers over manifolds is a must.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
