Swapped in a 408 what wires can I take out....
Old Aug 22, 2010 | 10:35 PM
IROCZRickyBobby's Avatar
Car: sho's/camaro
Engine: 406
Transmission: built 700r4
Axle/Gears: 456 gears and full posi
I still would like to be able to install ac later on, but I'm afraid of hacking the wiring...
is there a replacement wiring harness from some other camaro that will work??
thanks
Old Aug 22, 2010 | 11:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Swapped in a 408 what wires can I take out....
What year, auto or manual tranny, what was factory induction and what induction now?
Old Aug 22, 2010 | 11:26 PM
Car: sho's/camaro
Engine: 406
Sorry...
My car is a 86 iroc 305 tpi 700r4
converted to a 408 sbc with 700r4(all manual/no ecu needed)
I hooked up ,through the factory wiring,the ignition(off donor car),starter,and alt(I haven't confirmed if alt is working)
any info is much appeciated!
Old Aug 22, 2010 | 11:31 PM
Car: 1992 RS
Engine: Carbed 350
If it's carbed now, then most of the wiring from the pass side harness can come out - that's all the computer wiring - but for now until you verify that everything works, just tuck it all in the fenderwell. There will be a few wires that come from pass side harness and run through main harness to driver side maybe - like fuel pump relay wiring, wiring for ESC (spark control), maybe fan relay wiring.
You'll want to keep all driver side wiring, it should all get used.
Old Aug 22, 2010 | 11:42 PM
Car: sho's/camaro
Engine: 406
Do they unplug or do I need to go through them with a pair of wire cutters?
As of right now its a big mess of extra wires!
Old Aug 23, 2010 | 03:19 AM
smtrthanu17's Avatar
Car: 91 Camaro/bird
Engine: TBD
Transmission: TH400
Axle/Gears: 273LSD
The wires go through a plastic box on the inside of your fender. Unless you want to stick a plate there so there is not a big hole for water to splash into your car, I would just cut the wires from either side and leave the box. It will be a little bit ugly, but unless youre driving around without interior kick panels or fender wells, it will never be seen.
Old Aug 23, 2010 | 10:13 AM
Car: 1992 RS
Engine: Carbed 350
You should remove the harness in tact - like mentioned it connects in the pass wheel well, and the ECM is in the pass side under the dash/kick panel. The TPI harness is desireable by alot of folks, and can be sold if left in tact. Like I mentioned, there's a couple wires that run to the driver side that you might have to cut (if you don't have the time/patience to dig them out of the loom). Otherwise, the more 'in tact' you leave it, the better price it'll fetch.
Old Aug 31, 2010 | 11:26 PM
Car: sho's/camaro
Engine: 406
Ok update....
I have the car almost complete with an exception of exhaust from the cats to the rear.
I installed a electric fuel pump and removed the old one.
I also removed the tpi wiring harness and it wasn't as hard as I was thinking I didn't have to cut any wires
(I will sell the entire setup for $300 includes the ecu which I don't know the condition but it says its remanufactered)
I am a little frustrated because the performance seems not as good as it was in the donor car which was 5200 lbs
I think it could be due to the wires or plugs so I plan on changing them...
I don't know what cam I have, but it is really lumpy
Timing should be set near 13 btc?
Also I have a new problem:
After driving my ride for 15 minutes or so starts to die like its running out of gas, if I turn it off for a minute it will restart after priming the pump!
I thought the pump was bad so I changed it...with the same results!
Could it be the carb?
That guy helping istalled the dist. 180 backwards so it did backfire a couple of times until I figured it out!
Let me know what you think! I will be buying a accel coil and new plugs tommorrow for it!
thanks!
Old Sep 11, 2010 | 03:35 PM
Car: sho's/camaro
Engine: 406
Fuel lines where getting clogged due to rust in the metal lines/tank....carb is junk!
midge54
Sep 2, 2020 07:13 PM
camaro11j
Sep 19, 2018 08:49 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
nuggie
Aug 25, 2015 01:27 PM
355sbcTPI
Aug 19, 2015 04:38 PM
