Need a Q-jet any 4 sale????????
Old Aug 25, 2010 | 05:28 PM
91camarolt1's Avatar
Car: 1991 chevy camaro rs
Engine: 5.7 cid Lt1
Axle/Gears: stock
I have this intake and wondering if the Q-jet will bolt up to it. If anyone knows a place online to buy a q-jet, or if you have one you want sale. Please let me know. Thank you.
Old Aug 26, 2010 | 12:45 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Need a Q-jet any 4 sale????????
a qjet will fit on there no problem, as you can see the rear is set up for the larger secondaries
Old Aug 26, 2010 | 12:55 PM
sharkbait's Avatar
Car: 1975 Novamaro
Engine: 1988 305 TPI
Summit racing sells a bunch of different Q-Jets. Are you looking for one with computer controls (like the 80s Camaros and Monte Carlos) or old school? I have a few old ones in my garage that I messed around with a few years ago.
Old Aug 26, 2010 | 02:20 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
That intake has bolt patterns for both square and spread bore carbs.
Old Aug 26, 2010 | 05:17 PM
Engine: 5.7 cid Lt1
Axle/Gears: stock
I'm looking for a qjet that will run without a computer. Somewhere around a 700cfm. Thank you for letting me know that the intake I have will work for qjet.
Old Aug 26, 2010 | 06:37 PM
Damon's Avatar
For a Performance QJet you could try Summit (Jet I think makes performance QJets that they sell). You'll want a Stage 2 for a mild street performance application. Make sure to get one with an electric choke. Much easier to run a wire to it than figure out the tubing on a hot air style choke or linkage on an old divorced choke QJet when using an aftermarket intake.
Old Sep 4, 2010 | 05:23 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Have a look at this site.This guy does qjets in three stages dependent on motor needs.I've bought off him before and he does nice work.
Hope this helps,
Alicat.
http://www.smicarburetor.com/
Old Sep 10, 2010 | 07:07 AM
mjk1210's Avatar
Car: '83 TA
Engine: GM Performance 350
Axle/Gears: the slowest off the line
I've got one in my basement that's clean and cheap. I believe with electric choke. It's not doing anything for me so if you want I can send pics and we can talk.
69GTOby
Apr 18, 2016 02:34 PM
camaro1185
Oct 26, 2015 06:51 AM
aharvel50
Sep 21, 2015 07:31 PM
iroczz89
Sep 12, 2015 04:55 PM
funkyTA
Sep 10, 2015 06:38 PM
