Hard line kit?
Car: 85 Trans AM
Engine: Chevy 355
Hard line kit?
Is there a kit available to run hard fuel line from my (mech)fuel pump to carb like the one in this pic?
Or can someone point me in the direction on building my own?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Hard line kit?
I'd think you could use brake line from any autoparts store and bend it how you need, cut with a tube cutter, and flare your own ends as needed. Brake line comes in many diameters and as long as 4ft (that I've seen) which would be plenty long enough.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Hard line kit?
Yes, it's not brake line but fuel line. Get some bending tools while you're picking up the line, it's not as easy to bend as brake line is. Check to see that the fittings are compatible with what you have or bring the fitting in with you as well.
ambainb
Apr 25, 2016 09:21 PM
