What solvent to use to clean carb
Old Oct 5, 2010 | 02:53 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I got a carb from a friend of mine. It needs to be rebuilt and upon taking it apart there are a lot of whtie deposits and that kind of stuff. I am assuming that it is in those small passages... How do I clean those out?
Old Oct 5, 2010 | 02:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What solvent to use to clean carb
Carburetor cleaner... soak it if the deposits are heavy, then blow out the passages with the little straw on a spray can of cleaner, and afterwards flush them with compressed air.
Old Oct 20, 2010 | 05:17 PM
sdowney717's Avatar
I have also used plain white vinegar soaks. it cleans up a lot of metals including taking off the rust from steel after 2 days of soaking.
With carbs I soak for a few hours, rinse, and blow out with compressed air nozzle. I have thought about neutralizing the vinegar after the soak but have not done that yet.
The vinegar really cleans much better than I though it could.
Infested
May 22, 2018 11:56 PM
MantyZ28
23
Sep 29, 2015 11:33 AM
mdtoren
Aug 23, 2015 12:52 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
