Holley Model 4160 на 2,8 камаро 88'
Old Oct 26, 2010 | 08:07 AM
Reni-Camaro's Avatar
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
Hello!
My motor is 2.8 88
I want to install the carburetor Holley Model 4160
Someone that can say about him??
Old Oct 26, 2010 | 02:31 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Holley Model 4160 на 2,8 камаро 88'
Let's clarify a few things.
You have a 2.8 liter motor, 1988 model year?
You currently have fuel injection, and want to run a carburetor?
Doing this is possible, but the 4160 is much too large for that motor. You'll want a two barrel carburetor. You'll also need the correct intake manifold (Some chevrolet S-10 pickups had one I believe, as well as earlier camaros), vacuum advance distributor, and a way to lower the fuel pressure to around 6 psi
Old Oct 26, 2010 | 05:54 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
I also want to add you will need throttle and TV mounting brakets to make sure everything works right. And if you have and use cruise control you will need to get or find or make a braket for that as well. And to add to the post above me you will need to get a fuel pressure regulator to bring the fuel pressure down to 6psi, because most if not all aftermarkey electric fuel pumps pump well above 6, in fact they get real close to 15lbs. And it would be in your best intrest to go to the holley web site and use the carb selector to find the right size that is best for your car.
Old Oct 27, 2010 | 03:02 AM
Car: Camaro 1988
Yes, 1988!
I follow the advice!
http://static.summitracing.com/globa...-3789_inst.pdf
Also, I thought I put a mechanical gasoline pump, but no holes on the block!
Edelbrock Performer Intake Manifolds
I live in Ukraine!
I use translate google!
Sorry for the mistakes!
Old Oct 27, 2010 | 02:52 PM
If your block has no provisions for a fuel pump, use this : http://www.summitracing.com/parts/MAA-4309/
It will lower the fuel pressure from the electric pump in the fuel tank
You will also need this: http://www.summitracing.com/parts/PRO-67082/
That intake manifold you show will work. But it is 1.6 inches (4 cm) taller than a stock intake manifold, so it might hit the bottom of your hood.
Old Oct 28, 2010 | 03:23 AM
Car: Camaro 1988
Thank you!
I want to make here is the ignition
http://www.summitracing.com/parts/MAA-2769201/
Old Oct 28, 2010 | 10:48 AM
Why do you want to use that one? It is more expensive
Old Oct 29, 2010 | 02:52 AM
Car: Camaro 1988
you think it would be better??
I do not really understand how much the better!
Old Oct 30, 2010 | 01:29 AM
The HEI is very reliable, and easy to use and tune. This one costs less money.
Also, the distributor you want to use will not ship out until December at the earliest, it is not kept in stock. I do not know if that is important to you or not
Old Oct 30, 2010 | 08:33 AM
Car: Camaro 1988
Thank you!
Do you think better HEI Distributors???
Old Oct 30, 2010 | 08:34 AM
Car: Camaro 1988
Thank you!
Old Oct 31, 2010 | 02:48 PM
Yes, I think HEI distributors are better
Old Nov 1, 2010 | 05:57 AM
Car: Camaro 1988
What do you advise Air Filter Assembly under this carb??
Old Nov 1, 2010 | 07:36 PM
http://www.summitracing.com/parts/SUM-G3000/
This will work well
Old Nov 2, 2010 | 01:50 AM
Car: Camaro 1988
I thought this http://www.summitracing.com/parts/SUM-G3001/
it is cheaper Air Filter Element
what is a significant difference?
Old Nov 2, 2010 | 12:12 PM
The prices are the same.
The only difference is the top piece, one of them is blank or plain. The other has the company name on it.
That is the only difference, they are equal to each other
Old Nov 2, 2010 | 02:25 PM
Car: Camaro 1988
Air Filter Element 3000 Suggested Parts http://www.summitracing.com/parts/SUM-239318/
Air Filter Element 3001 Suggested Parts http://www.summitracing.com/parts/TRD-2110/
Why????
Old Nov 2, 2010 | 05:32 PM
I don't know why it suggests different parts...
You don't need to buy either of those parts though, since an air filter element comes with the air cleaner assembly. Those are just replacement air filters
Old Nov 3, 2010 | 12:28 AM
Car: Camaro 1988
thanks
I think that's what the ignition coil?
Old Nov 3, 2010 | 10:23 AM
The ignition coil is contained inside the HEI distributor
If that's what you are asking?
Old Nov 3, 2010 | 02:02 PM
Car: Camaro 1988
Sorry
I did not know that there is integration of the coil!
Old Nov 3, 2010 | 02:18 PM
Car: Camaro 1988
http://www.summitracing.com/parts/TAY-64600/
good???
Old Nov 3, 2010 | 11:41 PM
They look good to me
RedLeader289
May 28, 2019 01:47 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
paul_huryk
Oct 1, 2015 04:27 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
